- First, the gear is shaped radially (without a rolling motion) and in one position – this is called linear infeed. Only once this has been done does the rolling motion start and the other teeth are created.
- With helical infeed, on the other hand, all teeth are machined at the same time. The movement of the tool “into the depths” is therefore combined with the rolling motion. The first step here is a greater radial infeed, which is increasingly scaled back the deeper the tool penetrates the gearing.
- Electronic helical guide for helical gearing
- NC axis for shaping crowned and conical gearing
- Shuttle shaping
- Shaping of featherkey slots
- Double helical gearing
- Steady for machining gear shafts – can be retracted from the work area for shaping internal gearing.
- Tool changer for quickly switching from carbide roughing tools to HSS finishing tools.
Advantages Gear Shaping
- Flexible: Gear shaping machines can produce spur and helical internal and external gearing.
- Universal: They can machine many components for which other methods are not suitable.
(2) machines found
