Precision turning of 155 mm artillery shells with the EMAG USC 850
In the defense industry, maximum precision, reliability and efficiency are crucial. The USC 850 from EMAG fulfills these requirements exactly and enables the high-quality turning of 155 mm artillery shells.
Leading solutions for the defense industry: Maximum precision and performance
The USC 850 turning machine impresses with its generous machining area with a maximum turning diameter of 700 mm, specially optimized for 155 mm calibre artillery shells. High positioning and roundness accuracy ensure the ammunition subjected to machining has first-class ballistic properties. This technical accuracy is essential to meet the highest standards of safety and functionality.
General view of the EMAG USC 850 lathe for machining 155 mm artillery shells
The USC 850 lathe impresses with maximum precision and a robust design especially for machining 155 mm artillery shells.
Efficient machining of demanding materials
The USC 850 features an advanced 45° inclined bed design that offers outstanding static and dynamic rigidity. This reduces vibrations during the machining process to a minimum, which contributes significantly to the quality of the machined surface. The robust tailstock with a quill diameter of 150 mm ensures workpiece stability even with long and heavy artillery shells.
A 12-station turret, optionally equipped with powered tools, also enables flexible complete-machining in a single setup, thereby minimizing time and costs. The integrated coolant supply directly to the cutting edge also ensures extended tool life and improved surface quality of the machined components.
The powerful main spindle of the USC 850 offers a continuous output of up to 30 kW and a peak output of up to 37 kW over 30 minutes. This allows efficient and fast machining of high-strength materials typically used in the defense industry. Thanks to cylindrical roller bearings, the machine achieves a high spindle rigidity, which ensures consistently high precision even during heavy machining.
Detailed view of the work area of the USC 850 for the external processing of 155 mm artillery shells
USC 850 - Work area for external processing of 155 mm artillery shells
Fully automated solutions for your production requirements
EMAG offers integrated automation concepts that are tailored to your individual production requirements. The result is fully automated and efficient production lines that are specially tailored to the high safety and quality requirements of the defense industry. EMAG systems thus enable reliable, precision and economical machining of 155 mm artillery shells in both large and small batches.
Your advantages with the EMAG USC 850 at a glance:
  • Powerful machining: spindle power from 30 kW (continuous) to 37 kW (peak)
  • Optimized process reliability thanks to 45° inclined bed design
  • Flexibility in production thanks to turrets with driven tools
  • Sustainable production processes through targeted coolant supply
  • Customized automation solutions for maximum efficiency
Machines
(1) machines found
USC 850
Classic
  • Swing diameter: 800 mm | 31.5 in
  • Turning diameter, max.: 700 mm | 27.5 in
  • Maximum turning length: 2,000 mm | 78.5 in
