Machining of covers for 155 mm artillery shells with EMAG VL 4
Manufacturing components for artillery shells requires precision, efficiency and a sound technical understanding of the entire production process. As a leading supplier of manufacturing systems for the defense industry, we offer tailor-made solutions for machining covers for 155 mm artillery shells with our high-precision VL 4 machines.
Specialized production solutions with VL 4 machines for the highest quality requirements
Process-optimized manufacturing solutions for the defence industry
The cover is a critical component of the 155 mm artillery projectile and requires precision manufacturing to ensure the ballistic performance and reliability of the overall system. Our VL 4 vertical lathes have been specially designed for this demanding task, enabling highly efficient machining in four consecutive operations with minimal set-up times.
View of a finished cover for a 155 mm artillery projectile.
Detailed view of a cover for 155 mm artillery shells after machining on VL 4 machines for the defense industry.
Technical specifications of the VL 4 machine for cover machining
The VL 4 vertical turning machine offers the following advantages for machining cover components in the defense industry:
  • Precision positioning of workpieces for consistent quality
  • Optimized turret with 12 stations for flexible processing steps
  • Integrated coolant supply for longer tool life
  • Robust construction for machining high-strength materials
  • Automated loading and unloading for high-productivity production
Process for cover machining on VL 4 machines
The production process for the 155 mm artillery shell cover is divided into four operations (OP10-OP40).
Automated production lines for maximum efficiency
EMAG offers individually tailored automation solutions such as TrackMotion systems, which have been specially optimized for the requirements of the defence industry. These enable continuous, highly automated machining of covers for 155 mm artillery shells, reduce production costs and significantly improve process quality.
Integrated production line with four VL 4 machines for sequential machining of lids for 155 mm artillery shells in the defense industry, showing operations OP 10 to OP 40 with Track Motion System for workpiece interlinking
Fully automated production chain with 4 VL 4 machines for the precision machining of covers for the defense industry - from OP 10 to OP 40
Advantages of cover machining with EMAG VL 4 at a glance:
  • Fully automated vertical pick-up machining
  • High process reliability thanks to minimal manual intervention
  • Flexible complete-machining in a single setup
  • Optimized tool life and reduced non-productive times
  • Customized automation solutions for variable batches
(1) machines found
Vertical turning center VL 4 for chucked components up to 200 mm in diameter
VL 4
Modular
  • Workpiece length, max.: 200 mm | 8 in
  • Chuck dia., max.: 260 mm | 10 in
