Rifling with the PO 3000 IP: Precise internal contours for gun barrels using ECM rifling
ECM machine PO 3000 IP for rifling long gun barrels
The PO 3000 IP from EMAG ECM: High-precision ECM system for rifling tubes up to 3 meters long and 63 mm inside diameter.
High-precision internal machining with electrochemical processing
Gun barrel with visible rifling profiles, partially cut open to reveal the precise interior contour.
Illustration of a gun barrel with precisely manufactured rifling profiles – cut open to reveal the uniform contour of the interior machining.
Gun barrel production with ECM rifling
The production of gun barrels with tension-field profiles, also known as rifling, demands the highest levels of precision, repeatability and process reliability. The PO 3000 IP from EMAG ECM offers a solution for the electrochemical internal machining of rifled tubes: delivering stress-free machining, minimal tool wear and maximum reproducibility.
Engineered specifically for the requirements of defense technology, the PO 3000 IP machines tubes with internal diameters of up to 63 mm and lengths of up to 9,000 mm. This makes it ideally suited for manufacturing small- and medium-caliber barrels, such as those used in air defense systems, infantry weapons, helicopters and aircraft.
Advantages of Rifling Machining with the PO 3000 IP
1. Contactless Machining with ECM
Rifling is performed using Electro Chemical Machining (ECM), an electrolytic removal process with no mechanical contact between the tool and workpiece. This ensures:
  • No cutting forces or heat effects
  • Low cathode (tool) wear
  • No stress cracks or structural changes in the material
 2. Maximum Geometrical Precision
The rifling contour is defined by the shape of the cathode, achieving accuracies in the hundreths-of-a-millimeter range. Even complex geometries, such as gain twist, can be produced. The process allows full flexibility in adapting caliber, twist length and profile geometry to exact customer specifications.
 3. Machining of Hard and Tempered Materials
Unlike conventional processes such as broaching or hammer forging, ECM rifling is independent of material hardness. High-strength, tempered alloys can be machined without limitations.
 4. Significantly Reduced Machining Time
A 3 m long tube with a 22 mm internal diameter can be machined in about 35 minutes – dramatically faster than broaching, which requires several hours and tool changes.
 5. No Post-Processing Necessary
The process delivers a completely finished inner profile – free of thermal edge zones, with no need for additional measuring or straightening operations.
Cathode during rifling of a gun barrel with the PO 3000 IP ECM machine
Illustration of the electrochemical rifling process in the PO 3000 IP: The guided cathode generates precise tension-field profiles in the gun barrel.
Why ECM for rifling?
Compared to conventional rifling processes (broaching, cold hammering), the ECM process stands out for its material protection and flexibility:
Process Advantages of ECM (PO 3000 IP) Disadvantages of conventional processes
Tool wear Low wear, constant quality High risk of wear, high replacement requirement
Variety of materials All conductive materials can be machinedLimited choice of materials
Freedom of geometry Gain twist, asymmetrical profiles possible Limited profile variety
Processing length 3 m, optionally scalable up to 9 mUsually limited, high space requirement
Post-processing Not required Re-finishing and straightening often necessary
Scalability and Future Viability
ECM technology is inherently scalable to larger calibers and longer pipe lengths – for example, to internal diameters of up to 150 mm and component lengths exceeding 6 meters. This makes it suitable not only for artillery barrel systems but also for applications such as oil drilling technology. With this flexibility, the PO 3000 IP is more than just a solution for today’s requirements – it is a future-proof system ready to support emerging fields of application.
Technical data of the PO 3000 IP
Parameters Specification
Technology ECM (Electro Chemical Machining)
Area of application Rifling for gun barrels
Workpiece length 1,000 mm to 3,000 mm
Inner diameter 20 mm to 63 mm
Outer diameter up to approx. 121 mm (larger on request)
Feed speed up to 100 mm/min
Cycle time (example 3,000 mm pipe) approx. 35 minutes
Loading from above, e.g. by crane
ECM is the ideal technology for machining rifle barrels. The use of a special rifling module in the modular PI machine produces high-precision…
