成形磨床
G 375 H
- 模数范围: mm 0.5 - 15.0
- 工件最大直径: 375 mm | 15 in
- 工件最大长度: 870 mm | 34.5 in
Precision Grinding for Gears, Worms, and Rotors
The horizontal gear grinding machine G 375 H is ideal for precision grinding high quality parts such as gears, worms, screws, and rotors.
Gear Profile Grinding Machine G 375 H
The G 375 H horizontal gear grinding machine delivers high-precision grinding for external and internal gears, worms, crown gears, rotors, screws and more. Designed for versatility and efficiency, this universal machine is the ultimate solution for manufacturers seeking top-quality gear grinding results.
Applications of the G 375 H Gear Grinding Machine
The G 375 H is engineered to handle a wide range of gear grinding tasks, making it suitable for:
- External and Internal Spur Gears
- Helical Gears and Crown Gears
- Worm Gears and Splines
- Ball Screws for Linear Motion Systems
- Rotors for Air Compressors
- Screws for Hydraulic Pumps
This machine also supports the production of specialized profiles, such as asymmetric profiles and cycloid gears, using precise XY-coordinate inputs.
Enhance Productivity with the G 375 H
- Short Setup Times:
Maximize machine uptime with fast changeovers. - Integrated Gear Inspection:
Verify gear quality without additional processes. - High Flexibility:
Produce a wide range of profiles, including helical, spur and asymmetric designs.
Why Choose the G 375 H Horizontal Gear Grinding Machine?
The G 375 H offers the perfect balance of versatility, precision and efficiency, making it a top choice for manufacturers of gears, rotors and screws. With its modular design, advanced technology and exceptional accuracy, this machine adapts to your production needs while delivering consistent, high-quality results.
Ready to Revolutionize Your Gear Manufacturing Process?
Experience the precision and reliability of the G 375 H horizontal gear profile grinding machine from EMAG. Contact us today to learn how this machine can optimize your gear production processes.
优势 G 375 H
- High Stability and Precision: A rigid machine structure ensures a stable grinding process, with direct-drive and linear motors enhancing accuracy and reliability across all axes.
- Superior Product Quality: Delivers exceptional precision for gears and components, meeting tight tolerances and with integrated gear inspection.
- Versatile and Flexible Production: Handles components ranging from 30mm internal gears to large external gears, with quick transitions and minimal setup time.
- Easy Tool Changes: Simple and efficient tool changes allow for quick adjustments between different gear profiles and components.
- Customizable to Your Needs: A modular design supports tailored configurations and integrates seamlessly with automation systems for streamlined workflows.
技术数据
模数范围
0.5 - 15.0 mm
工件最大直径
375 mm
15 in
工件最大长度
870 mm
34.5 in
| 模数范围 | mm | 0.5 - 15.0 |
| 工件最大直径 |
mm
in |
375
15 |
| 工件最大长度 |
mm
in |
870
34.5 |
| Profile depth, max. |
mm
in |
35
1.5 |
| Centre dist. work spindle / tool spindle |
mm
in |
35
/ 340
1.5 / 13.5 |
| Tool spindle power |
kW
hp |
23
31 |
