连续展成磨齿机
SG 160
- Module range: mm 1.0 – 3.5
- 工件最大直径: 160 mm | 6.5 in
- 工件最大长度: 300 mm | 12 in
Gear Dry Grinding SG 160 SKYGRIND
The SG 160 SKYGRIND is the first gear dry grinding machine in the world. It ensures cycle times for finishing of gears that are perfectly in line with the automotive industry at a lower cost compared to traditional manufacturing solutions.
First Gear Dry Grinding Machine in the World
The SG 160 SKYGRIND is the first gear dry grinding machine in the world. This state-of-the-art process eliminates the need for cooling oil during the hard finishing grinding of the toothed gear after the heat treatment.
On the SG 160 SKYGRIND machine the process is split in two main passes: roughing and finishing. For the roughing process skive hobbing is implied, whereas worm grinding is used for the finishing process. The SG 160 SKYGRIND removes about the 90% of the stock allowance with the first pass using a hobbing tool, which has the advantage of not heating the workpiece excessively. Subsequently, with the second finishing pass, a grinding wheel removes the remaining stock without causing problems of overheating the workpiece, therefore resulting in a completely dry process. Moreover, its innovative structure with two spindles actuated by linear motors and the use of more channels simultaneously ensure a time of chip-to-chip of less than 2 seconds.
The SG 160 SKYGRIND splits the X-axis of traditional machines into two linear slides (X1, X2), each of which carries tools spindles. In this way both workspindles are under full position control any time. Being driven by high dynamic 30 m/s linear motors, changing spindles come down to less than 2 seconds including simultaneous repositioning of the tools with the Y-Z-A axes.
The new grinding SG 160 SKYGRIND of Samputensili ensures cycle times for the finishing of gears that are perfectly in line with the automotive industry, at a lower cost compared to traditional manufacturing solutions. The SG 160 SKYGRIND is an amazingly productive machine, even faster than traditional dual table grinding machines, characterized by a very small footprint and a lower cost of investment for auxiliary equipment. More importantly, by totally eliminating the need for cutting oils, the machine is extremely environmental friendly.
Significant reduction in:
- cost of consumables
- total investment
- machine footprint
Significant improvement of:
- work health
- environmental impact
优势 SG 160
- High productive machine
- Chip-to-chip time less than 2 sec.
- Innovative and patent-pending machine architecture
- Dual tool spindles: one for skive-hobbing, one for generating grinding
- New virtual tangential axis configuration for high dynamic stiffness
- High thermal and mechanical stability
- Automatic meshing of the first workpiece (with both tools)
- Inductive alignment sensor on the workpiece – spindle
技术数据
Module range
1.0 – 3.5 mm
工件最大直径
160 mm
6.5 in
工件最大长度
300 mm
12 in
Module range | mm | 1.0 – 3.5 |
工件最大直径 | mm in | 160 6.5 |
工件最大长度 | mm in | 300 12 |
Face width, max. | mm in | 180 7 |
Helix angle degree | +95° / -45° | |
砂轮直径 | 250 max / 210 min |
We're here for you
To contact
