CNC Grinding – Grinding Technologies for Maximum Dimensional and Geometric Accuracy
CNC grinding enables the precision finishing of chucked components, shafts, and special workpieces. EMAG offers tailored grinding processes – from cylindrical grinding and out-of-round grinding to the combined process of hard turning and grinding – for efficient and repeatable manufacturing processes.
Grinding Technologies at a Glance: Versatile, Precise, and Cost-Effective
Grinding as a Key Process in Hard Finishing
CNC grinding is the final step in many manufacturing process chains and ensures the highestdelivers top dimensional and geometric accuracy. Conventional methods like turning often can’tfail to meet the required tolerances or leave behind unwanted machining marks. Grinding closes that gap, machining hard materials with consistently high surface quality. EMAG offers the right machine solution for virtually every application – from vertical grinding machines for turned parts to CNC cylindrical grinding machines for shaft parts.
Cylindrical Grinding: The Solution for Shafts and Cylindrical Parts
In cylindrical grinding, round and cylindrical workpieces are machined for maximum roundness – both internally and externally.  EMAG’s HG series CNC cylindrical grinding machines are designed balanced flexibility and productivity, mainly for high-productivity batch production.
Hard Turning and Grinding: Combined Machining for Greater Efficiency
Combining hard turning and grinding on a single machine cuts cycle times sharply: transport, dwell, and setup times largely disappear, since all quality-critical surfaces are machined in a single setup. Typical applications include gear wheels, thrust rings with a non-twist surface, and nuts for ball screws. EMAG offers machines for both chuck and shaft parts.
Work area of the EMAG VTC 100 GT during CNC grinding of shafts.
The VTC 100 GT combines CBN grinding, hard turning, and Scroll free turning in a single machine. All finishing processes are performed in a single setup, minimizing setup times. Unique flexibility in the finishing of shaft components.
Universal Grinding: Complete-Machining in a Single Setup
Universal grinding machines combine internal, external, and out-of-round grinding on a single machine. Complex geometries – such as shoulders, tapered sections, or flutes – can be machined in a single setup, eliminating reclamping errors and reducing lead time. The EMAG UG series includes four models (UG 400, 630, 1000, 1500) with grinding lengths from 400 to 1,500 mm. CNC control, optical measurement systems, and adaptive process control hold tight tolerances with high repeatability – keeping the process economical even for individual parts and small to medium batches.
Out-of-Round Grinding: High-Precision Machining of Out-of-Round Geometries
Camshafts, cam discs, and pump rings require an out-of-round final shape from grinding rather than a circular contour. Out-of-round grinding with CBN technology is the state of the art for this application. It enables rough and finish grinding in a single setup and – with multiple grinding spindles – machining of multiple contours. EMAG’s modular machine and technology concept adapts flexibly to the specific manufacturing task, for example, complete-machining of camshafts for commercial vehicles with up to twelve cams.
Synchro Support Grinding: Precision Grinding of Slim Shafts
In synchronous support grinding, slender or unstable shafts are machined simultaneously from two sides using CBN grinding wheels. The opposing wheel arrangement eliminates the normal forces, while a synchronously adjusted steady rest absorbs the remaining tangential forces. The result: grinding time is roughly halved compared to single-sided CBN grinding, with improved surface roughness, concentricity, roundness, and short-wave runout.
Advantages
  • Shorter lead times: Combining multiple grinding processes on a single machine eliminates transport, idle, and setup times between operations.
  • Top dimensional and geometric accuracy: CNC-controlled grinding processes with integrated measuring probes deliver reproducibly tight tolerances – even in hardened materials.
  • Flexible workpiece machining: Round shafts, out-of-round camshafts, or complex chucked components – EMAG grinding technologies cover a wide range of workpieces on a modular machine concept.
  • Complete-machining in a single setup: Eliminating reclamping errors is particularly crucial for surfaces requiring precise positioning and form, like ball raceways or non-twist seats.
  • Cost-effectiveness through CBN technology: CBN grinding wheels achieve shorter active times and long tool life, reducing non-productive time in batch production.
  • Scalable machine solutions: From vertical grinding machines for small chucked components to CNC cylindrical grinding machines for large shafts, EMAG offers the right grinding machines for every production volume.
Questions and Answers
CNC grinding is a subtractive manufacturing process in which a rotating grinding tool with geometrically undefined cutting edges removes material from the workpiece surface. The CNC control precisely regulates feed, depth of cut, and dressing cycles,enabling reproducible dimensional, geometric, and surface accuracy even in hard materials. Grinding  typically occurs at the end of the process chain, producing the required final quality.
The range spans rotationally symmetrical shafts and chucked components to camshafts and pump rings, as well as gear wheels, ball screws, and pressure cylinders. The deciding factors are geometry, hardness, and quality requirements: Cylindrical parts are machined using cylindrical grinding, out-of-round contours using out-of-round grinding, and hardened chucked components are often machined using a combination of hard turning and grinding.
EMAG offers a coordinated portfolio: cylindrical grinding (HG series) for high-volume production of shafts and cylinder parts, Universal Grinding (UG series) for complete-machining of complex geometries, out-of-round grinding for camshafts and pump rings, and the combination of hard turning and grinding for chucked and shaft parts in hard finishing. Synchro support grinding rounds out the portfolio for slender, unstable shafts.
Flat shoulders and non-critical surfaces are hard turned first. Bores, tapers, and quality-critical O/Ds are then pre-ground and finished on the same machine. For gear wheels, for example, grinding removes only a few hundredths of a millimeter of material, allowing short grinding times and a wheel-specific tool design. All operations happen in a single setup.
For shaft machining, the UG series of universal grinding machines, the HG series of CNC cylindrical grinding machines, and the VT series of vertical machines are available. Beyond cylindrical grinding, the VT series also handles synchronous support grinding and the combined hard turning and grinding process. For demanding camshafts,  the SK and SN series handle curve and cam grinding, while the PM series is built for crankshafts.
The automotive industry and its suppliers are the largest market – for camshafts, crankshafts, transmission components, and bearing rings. General machinery manufacturing, aerospace, and tool and mold making industries also rely on EMAG grinding technologies. CNC grinding machines are essential wherever hardened materials must be machined with the highest precision.
Combining multiple grinding processes on a single machine reduces the number of systems needed, lowers investment and operating costs, and shortens lead times. CBN- grinding wheels can also reduce the main lead time compared to conventional wheels, while offering a longer service life. Integrating hard turning and grinding virtually eliminates setup and transport times – a key lever for streamlining series and mass production.
This demand is met with…
The synchronous support grinding process on the VTC 315 DS uses two CBN grinding wheels to simultaneously grind – from opposite sides – vertically…
Universal grinding of chucked components involves the combined internal and external grinding of a workpiece on one machine. Even complex geometries…
